1962 WSRC - season over, future unknown
Posted: 16 Apr 2015, 19:14
So here it is. The "60s sportscar series" that I've planned for over two years, mainly on the IRC channel. The idea began as the Porsche 356B Cup in late 2012, and some of the research (mainly tracks) originates from that. However, it never happened as taking on a third series besides RoLFS and LGPS would've been too much. I then started to expand the series sporadically whenever I had the time and interest to work on it, first using cars readily available for F1C and then by starting to convert cars from rFactor. As LGPS had come to an end sometime earlier and IFRC was in its off-season, I was first planning to launch the series in the spring of 2014, but then I got a job and my free time reduced significantly. By the time I had more time on my hands again, the 2017 ASMF season was about to start and I had to concentrate on AR 3.5 (which was then delayed by a broken ankle preventing me from using my computer for a month).
With the ASMF season now entering its traditional summer hibernation and my "side project" Reject Ice Hockey mostly complete, I feel that I finally have enough time and interest to do this. For the past few weeks I've spent a lot of time researching data for all of the car models featured in the series and their numerous variants, from horsepower ratings (many manufacturers of this time advertised their engines with gross HP ratings instead of net so it took a lot of research to find the actual realistic figures) to top speeds to fuel tank capacities. I even found one more car to convert.
Everything is now ready for the inaugural season set in 1962. The starting year was first based on the season defined in the Porsche 356B mod, and has stuck around as it fits the availability of most car models quite well. Much of the stuff for further seasons remains unfinished (including most car conversions), but these will be worked on eventually as the series progresses. The series will end after 1970, to mark the end of an era when racing cars were still fairly closely related to ordinary road cars. As I will only list the cars available for this season in the next post, you might want take a look at the full list of cars planned for the series if you want to plan further ahead. The cars are classified based on how simple their livery template is.
Many aspects of the series will be heavily controlled by me to ensure realism and fair play. RNG won't be used for anything except defining fictional drivers, and in the case of multiple teams bidding for the same real-life driver. I will decide which users get to run which manufacturers based on these users' previous track record on this forum. The usage of some car models is also controlled, as are the liveries of the cars. If you aren't happy at the likely prospect of me interfering with your plan, then the series is not for you.
While using many car models that appeared in it, this is not intended to replace World Sportscar Championship in the canon. The WSC was mostly based on endurance events, which would be too ardurous to run on F1C, not in the least because due to technical limitations I probably have to run multiple starts for the various competition classes. Also, long races would likely be quite boring to watch. This is why the series' title refers to sprint racing, as that somewhat accurately describes the format used here (100-150 km races).
Entry process
There are four types of teams/entrants in the series: factory teams, full-time privateers, part-time privateers and local one-off entrants. Factory teams can enter a maximum of five, full-time privateers three, and part-time privateers two cars per race. Local one-offs can either enter one car under the entry name of the driver him/herself or form a team of a maximum of three cars, and as they can only enter one race in the whole season they can be entered at any time. Additionally, each team/entrant has a maximum amount of "active entries" (see below). The names of each factory team are pre-defined while privateer entrants can be freely named (as long as it remains in good taste), with both real-life and fictional entrants allowed. Factory teams can only run their own products while privateers can freely mix various models from different manufacturers. The maximum amount of teams/entrants one user can control at any given time is one factory team, one full-time privateer, one part-time privateer and three local one-offs per each race. Users not running a factory team can run another full-time privateer instead. In hopes of ensuring a diverse grid, each team/entrant controlled by the user must run different car models. To avoid having to redo liveries, everyone will get a permanent number which is theirs for the whole season, even if they enter just one race.
"Active entries" means the amount of races where the team is currently entered for. To prevent people from entering the whole season at the start of the year and then going inactive, no team can have active entries beyond the predefined limits. As the season progresses you can enter further races, but only up to the given limits. The limits are as follows:
Factory teams - 50% of the season or 6 races, whichever is less
Full-time privateers - 3 races
Part-time privateers - 2 races
Local one-offs - 1 race
Car limitations
Besides being classified in various categories based on engine capacity for competition purposes, the availability of many models and variants thereof is limited to keep the entry lists variable and retain realism as many of the cars featured were only built in small numbers. The categorization of each model variant is based on real-life manufacturing figures and other data. The four categories are as follows:
Stock: the model variant is widely available for normal customers. Privateers can get these without the manufacturer's permission and replace wrecked examples easily.
Limited: the model variant is only available in limited numbers. Privateers need to ask for the manufacturer's permission to obtain these, and have to do so again should they want to expand their existing fleet or replace a wrecked example. If no spare cars (see below) are available, the privateer has to wait for a set amount of time (usually a race or two) as the new car is being built. Factory teams can get these whenever they need one without limitations.
Super-limited: the model variant is only available in very limited numbers. Similar to limited, except the factory team is subject to the same availability limitations as privateers. Should the factory team lose one of these cars in a wreck and have no spare cars available, they have to confirm if they are going to build a new one and then wait for some time for the work to be finished. As a quick solution factory teams are allowed to borrow or repossess (depending on the terms agreed between the manufacturer and privateer) cars previously given to privateers. The total amount of these cars available can also be limited by me to keep the game realistic.
Factory only: the model variant is only available in extremely limited numbers and cannot be sold to privateers. This category is mainly reserved for experimental one-offs and early models of some cars.
As written above, cars can be wrecked beyond repair in accidents and collisions. Factory teams can at any given time hold a maximum of two spare cars of their limited models, which can only be used in races to replace wrecked examples without having to wait for a new example to be built. These spare cars can also be given to privateers should they need one quickly. Privateer teams are not allowed to keep spare cars of their own. Once a spare car is entered in a race a new example can be built with the standard waiting time.
Drivers
Both fictional and real-life drivers are allowed, although as the series coexists alongside other series of the era instead of replacing one I'm only allowing RL drivers that weren't regularly participating elsewhere. Regular participation means more than 10 F1 (both championship and non-championship, as found on StatsF1) and sportscar races (listed on racingsportscars.com) combined. DNQs count towards this total, but WDs and DNAs don't. Fictional drivers will be RNGed while I'll try to base the RL drivers on their actual results, depending on how much data is available. A driver can only compete in one class each weekend. It should be noted though that in this series much of the performance is based on the car, not the driver. Serious injuries and even death are also possible here.
Liveries
For purposes of realism the complexity of liveries is limited. Only a maximum of two main body colours with a simple paint scheme is allowed. Alternatively racing stripes can be used. You don't need to use national racing colours, but try to avoid car colours not commonly used in the 60s. The racing number must be well visible, placed on at least the doors/sides of the car and preferrably inside a circle or a square to increase visibility even further. Little to no sponsorship is allowed, mainly by technical partners (oil/fuel/tyre/parts suppliers). Livery templates are here. Some of the "templates" are just flat skin files extracted from the MAS files and might be hard to paint on, but then again due to the livery restrictions you don't need to create works of art. There are notes and/or example pics included with each template to help with the process. Also, if a template contains space for a registration plate, either figure out something for it or leave it blank. I don't want to see multiple cars with the same registration plates.
Points system
There will be a manufacturers' and drivers' championship for each class. The manufacturers' championship will use the same points system as the 1962 World Sportscar Championship: 9-6-4-3-2-1 with only the best car of each manufacturer scoring points. In the case of multiple cars from the same manufacturer finishing in points, these results are skipped and the points are not redistributed to lower-placing cars. So for example if Jaguar finishes 1st and 3rd, Ferrari 2nd and 6th and Aston Martin 4th and 5th, only the 9 points for the 1st place are given to Jaguar, with Ferrari only getting 6 points from the 2nd place and Aston Martin 3 points from the 4th place. In this example the points for 3rd, 5th and 6th are not awarded to any manufacturer as the positions were locked out by manufacturers which all had cars finishing in better positions. The drivers' championship uses the same 9-6-4-3-2-1 scoring, but all points are awarded normally.
The possession list can be found here, listing the cars owned by each team and their drivers.
Calendar
16th-18th March: Warwick Farm Raceway, Warwick Farm, New South Wales, Australia (28)
6th-8th April: Prince George Circuit, East London, South Africa (28)
27th-29th April: Autodromo di Monza, Monza, Italy (35)
11th-13th May: Circuit de Rouen-Les Essarts, Rouen, France (35)
8th-10th June: Brands Hatch, Swanley, Kent, United Kingdom (35)
29th June-1st July: Circuit de Spa-Francorchamps, Francorchamps, Belgium (35)
27th-29th July: Roskilde Ring, Roskilde, Denmark (28)
10th-12th August: Nürburgring, Nürburg, West Germany (30+)
7th-8th September: Mosport Park, Bowmanville, Ontario, Canada (30+)
21st-23rd September: Daytona International Speedway, Daytona Beach, Florida, USA (28)
12th-14th October: Autódromo de la Magdalena Mixhuca, Mexico City, Mexico (30+)
2nd-4th November: Autódromo Municipal Ciudad de Buenos Aires, Buenos Aires, Argentina (30+)
Entry lists for each race (car / entrant / driver)
Entry list for the CAMS Warwick Farm Sprint Race
GT +3.0
#39 Shelby Cobra 260ci / Shelby American Inc. (USA) / Gerson Alarcón Santana (PAN)
#40 Shelby Cobra 260ci / Shelby American Inc. (USA) / Alvaro Mazzacane Sr. (ARG)
#5 Aston Martin DB4 GT Zagato / David Brown Racing Department (GBR) / Peter Harper (GBR)
#6 Aston Martin DB4 GT Zagato / David Brown Racing Department (GBR) / Jack Sears (GBR)
#7 Aston Martin DB4 GT Zagato / David Brown Racing Department (GBR) / John Campbell-Jones (GBR)
#32 Jaguar E-Type 3.8 FHC racing / Jaguar Cars Ltd. (GBR) / Paul Frère (BEL)
#33 Jaguar E-Type 3.8 FHC racing / Jaguar Cars Ltd. (GBR) / Umberto Maglioli (ITA)
#34 Jaguar E-Type 3.8 FHC racing / Jaguar Cars Ltd. (GBR) / Vic Elford (GBR)
#19 Maserati 3500 GTi Corse / Scuderia Filipinetti (ITA) / Francesco Fausti (ITA)
#555 Maserati 3500 GTi Corse / Scuderia Filipinetti (ITA) / Giorgio Scarlatti (ITA)
#922 ZiL-112S / State Committee for Sports and Body Culture of USSR (URS) / Angelina Sokoloff (URS)
#900 Ford Falcon Holman & Moody Challenger 1 / Ford Motor Company (USA) / Roy Pierpoint (GBR)
#901 Ford Falcon Holman & Moody Challenger 1 / Ford Motor Company (USA) / Peter Procter (GBR)
#902 Ford Falcon 221ci / Ford Motor Company (USA) / Henry Taylor (GBR)
#444 Jaguar E-Type 3.8 FHC racing / Bib Stillwell (AUS) / Bib Stillwell (AUS)
GT 3.0
#56 Austin-Healey 3000 BJ7 Rally / Donald Healey Motor Company (GBR) / Heinz Schiller (SUI)
#22 Ferrari 250 GTO / Scuderia Ferrari SpA SEFAC (ITA) / Ludovico Scarfiotti (ITA)
#23 Ferrari 250 GTO / Scuderia Ferrari SpA SEFAC (ITA) / Willy Mairesse (BEL)
#27 Ferrari 250 GTO / Scuderia Ferrari SpA SEFAC (ITA) / Giancarlo Baghetti (ITA)
#28 Ferrari 250 GTO / Scuderia Ferrari SpA SEFAC (ITA) / Simone Bizzarri (ITA)
#90 AC Ace 2.6/V / AC Cars Ltd. (GBR) / Jack Fairman (GBR)
#91 AC Ace 2.6/V / AC Cars Ltd. (GBR) / Peter Ryan (CAN)
#92 AC Ace 2.6/V / AC Cars Ltd. (GBR) / Colin Davis (GBR)
#93 AC Ace 2.6/V / AC Cars Ltd. (GBR) / Sidney Hunter (GBR)
#24 Ferrari 250 GTO / North American Racing Team (USA) / Pedro Rodriguez (MEX)
GT 2.0
#14 Lotus 23 / Team Lotus Engineering (GBR) / Peter Arundell (GBR)
#15 Lotus 23 / Team Lotus Engineering (GBR) / Denny Hulme (NZL)
#16 Lotus 23 / Team Lotus Engineering (GBR) / Hachiman Setou (JPN)
#11 Porsche 356B 1600 GS Carrera GT / Ecurie Maarsbergen (NED) / Rob Slotemaker (NED)
#12 Porsche 356B Super 90 / Ecurie Maarsbergen (NED) / Henk van Zalinge (NED)
#58 MG A 1600 Twin-Cam / British Motor Corporation (GBR) / Paddy Hopkirk (GBR)
#44 Sunbeam Alpine Series II racing / Sunbeam Talbot (GBR) / George "Doc" Shepherd (GBR)
#45 Sunbeam Alpine Series II racing / Sunbeam Talbot (GBR) / Ralph Bowyer (USA)
#66 MG A 1600 Twin-Cam / Anglo Racing Engineering (GBR) / Alan Foster (GBR)
#59 Lotus Elite Super 95 / Zimmer Racing Enterprises (AUS) / James Zimmer (AUS)
#75 Alfa Romeo Giulietta Coupé Sprint Speciale / Alfa Corse (ITA) / Henry C. Bradley (PER)
#76 Alfa Romeo Giulietta Coupé Sprint Speciale / Alfa Corse (ITA) / Karl Foitek (SUI)
#77 Alfa Romeo Giulietta Coupé Sprint Speciale / Alfa Corse (ITA) / Pedro Bello (MEX)
#31 Porsche 356B 2000 GS Carrera 2 / Porsche System Engineering (FRG) / Herbert Linge (FRG)
#47 Porsche 356B 2000 GS Carrera 2 / Porsche System Engineering (FRG) / Edgar Barth (FRG)
#48 Porsche 356B 2000 GS Carrera 2 / Porsche System Engineering (FRG) / Hans Herrmann (FRG)
#49 Porsche 356B 1600 GS Carrera GT / Porsche System Engineering (FRG) / Sepp Greger (FRG)
#61 Triumph TR4 racing / Standard Triumph Ltd. (GBR) / Brian Naylor (GBR)
#62 Triumph TR4 racing / Standard Triumph Ltd. (GBR) / Gerry Ashmore (GBR)
#200 TVR Grantura Series III / TVR Cars Ltd. (GBR) / Christabel Carlisle (GBR)
#201 TVR Grantura Series III / TVR Cars Ltd. (GBR) / P.J. Woodroffe (GBR)
#52 VW Karmann Ghia Super 90 / Volkswagenwerk AG (FRG) / Gerhard Mitter (FRG)
#53 VW Karmann Ghia 1500 / Volkswagenwerk AG (FRG) / Helmut Busch (FRG)
#54 VW Karmann Ghia 1500 / Volkswagenwerk AG (FRG) / Peder Larsson (DEN)
#43 Peugeot 404 Super Luxe Injection / Peugeot S.A. (FRA) / Joop Heidendahl (NED)
#80 Peugeot 404 Super Luxe Injection / Peugeot S.A. (FRA) / Fernand Tavano (FRA)
#94 Peugeot 404 Rallye / Peugeot S.A. (FRA) / Jo Schlesser (FRA)
GT 1.0
#84 MG Midget 950 / British Motor Corporation (GBR) / John Sprinzel (GBR)
#87 Mini Cooper / British Motor Corporation (GBR) / Warwick Banks (GBR)
#88 Mini Cooper / British Motor Corporation (GBR) / Frank Gardner (AUS)
#67 Mini Cooper / Anglo Racing Engineering (GBR) / John Love (RHO)
#110 Alpine A110 1000 75 Berlinette / Société Automobiles Alpine (FRA) / Mauro Bianchi (BEL)
#111 Alpine A110 1000 75 Berlinette / Société Automobiles Alpine (FRA) / Henri Grandsire (FRA)
#112 Alpine A110 1000 75 Berlinette / Société Automobiles Alpine (FRA) / Jean Vinatier (FRA)
#96 Saab 96 Rally / Saab AB (SWE) / Bo Ljungfeldt (SWE)
#960 Saab 96 Rally / Saab AB (SWE) / Freddy Kottulinsky (SWE)
#961 Saab 96 Sport / Saab AB (SWE) / Per Olsen (NOR)
#962 Saab 96 Sport / Saab AB (SWE) / Björn Larsen (SWE)
#101 BMW 700 RS / Bayerische Motoren Werke AG (FRG) / Hubert Hahne (FRG)
#102 BMW 700 RS / Bayerische Motoren Werke AG (FRG) / Walter Schneider (FRG)
#103 BMW 700 RS / Bayerische Motoren Werke AG (FRG) / Fritz Hahnl, Jr. (FRG)
#104 BMW 700 RS / Bayerische Motoren Werke AG (FRG) / Sepp Liebl (FRG)
#8 Fiat Abarth 850 TC SS / Abarth Corse SpA (ITA) / Gaetano Starrabba (ITA)
#9 Fiat Abarth 850 TC SS / Abarth Corse SpA (ITA) / Syd van der Vyver (SAF)
#10 Fiat Abarth 850 TC SS / Abarth Corse SpA (ITA) / Paul Russo (USA)
Entry list for the AASA East London Sprint Race
GT +3.0
#922 ZiL-112S / State Committee for Sports and Body Culture of USSR (URS) / R. I. Goldin (URS)
GT 3.0
GT 2.0
#14 Lotus Elite Super 105 / Team Lotus Engineering (GBR) / Peter Arundell (GBR)
#15 Lotus Elite Super 105 / Team Lotus Engineering (GBR) / Denny Hulme (NZL)
#16 Lotus Elite Super 105 / Team Lotus Engineering (GBR) / Hachiman Setou (JPN)
#66 MG A 1600 Twin-Cam / Anglo Racing Engineering (GBR) / Gene Bosman (SAF)
#76 Alfa Romeo Giulietta Coupé Sprint Speciale / Alfa Corse (ITA) / Carlo M. Abate (ITA)
#25 Morgan Plus 4 Super Sports Lawrence Tune / Morgan Motor Company (GBR) / Lord Montgomery Sterling (GBR)
#26 Morgan Plus 4 Super Sports Lawrence Tune / Morgan Motor Company (GBR) / Geoff Richardson (GBR)
#290 Morgan Plus 4 Super Sports Lawrence Tune / Morgan Motor Company (GBR) / Chris Lawrence (GBR)
#98 Citroën DS Connaught GT / Citroën S.A. (FRA) / Pauli Toivonen (FIN)
#99 Citroën DS Connaught GT / Citroën S.A. (FRA) / Paul Coltelloni (FRA)
GT 1.0
#3 Alpine A110 1000 75 Berlinette / Ecurie Voeckler (FRA) / André Simon (FRA)
#4 Alpine A110 1000 75 Berlinette / Ecurie Voeckler (FRA) / Jean-François Voeckler (FRA)
#55 Lotus Seven F / Douglas-Cliff Racing (GBR) / Tony Douglas (GBR)
Entry list for the ACI Gara Corta a Monza
GT +3.0
#900 Ford Falcon Holman & Moody Challenger 1 / Ford Motor Company (USA) / Marvin Panch (USA)
#901 Ford Falcon Holman & Moody Challenger 1 / Ford Motor Company (USA) / Jocko Maggiacomo (USA)
#902 Ford Falcon 221ci / Ford Motor Company (USA) / Darel Dieringer (USA)
#903 Ford Falcon 221ci / Ford Motor Company (USA) / Peter Revson (USA)
GT 3.0
#18 Ferrari 250 GTO / North American Racing Team (USA) / Augie Pabst (USA)
#20 Ferrari 250 GT Berlinetta SWB Competizione Speciale / Ecurie Francorchamps (BEL) / "Jean Beurlys" (BEL)
#501 Fiat 2300 S Coupé / Abarth Corse SpA (ITA) / Ricciardo Ricci (ITA)
GT 2.0
#75 Alfa Romeo Giulietta Coupé Sprint Speciale / Alfa Corse (ITA) / Oscar A. Gálvez (ARG)
#200 TVR Grantura Series III / TVR Cars Ltd. (GBR) / TBC (TBC)
#21 Lotus Super Seven / Ecurie Francorchamps (BEL) / Gérald Langlois van Ophem (BEL)
#904 Ford Anglia Cosworth / Ford of Britain (GBR) / Roy Pierpoint (GBR)
#17 Alfa Romeo Giulietta Spider Sprint Veloce / Jens König (GDR) / Jens König (GDR)
GT 1.0
#88 Mini Cooper / British Motor Corporation (GBR) / John Rhodes (GBR)
#10 Fiat Abarth 850 TC SS / Abarth Corse SpA (ITA) / Giancarlo Sala (ITA)
#500 Fiat Abarth 850 TC SS / Abarth Corse SpA (ITA) / Teodoro Zeccoli (ITA)
Entry list for the Course Sprint de l'ACF à Rouen
GT +3.0
GT 3.0
#65 Ferrari 250 GT California Spyder / Equipo Castelldefels / Edoardo Lualdi (ITA)
#66 Ferrari 250 GT California Spyder / Equipo Castelldefels / Juan Manuel Bordeu (ARG)
GT 2.0
#58 MG B Rally / British Motor Corporation (GBR) / Paddy Hopkirk (GBR)
#290 Morgan Plus 4 Super Sports Lawrence Tune / Morgan Motor Company (GBR) / Richard Shepherd-Barron (GBR)
#122 Volvo 122 S Rally / Volvo AB (SWE) / Tom Trana (SWE)
#154 Volvo 122 S Rally / Volvo AB (SWE) / Gunnar Andersson (SWE)
GT 1.6
#200 TVR Grantura Series III / TVR Cars Ltd. (GBR) / Pat Moss (GBR)
#201 TVR Grantura Series III / TVR Cars Ltd. (GBR) / Tommy Entwistle (GBR)
#45 Sunbeam Alpine Series II racing / Sunbeam Talbot (GBR) / Giorgio Becucci (ITA)
#68 Lotus Elite Super 95 / Chester Automotive Racing (GBR) / David Buxton (GBR)
#69 Lotus Elite Super 95 / Chester Automotive Racing (GBR) / Robin Sturgess (GBR)
GT 1.0
Entry list for the RAC Brands Hatch Sprint Race
GT +3.0
#78 Shelby Cobra 260ci / All American Eagles (USA) / Peter Sutcliffe (GBR)
#29 Jaguar E-Type 3.8 FHC racing / Irish Racing Cars (IRL) / Paddy Hopkirk (GBR)
#30 Jaguar E-Type 3.8 FHC racing / Irish Racing Cars (IRL) / Desmond Titterington (GBR)
#902 Ford Falcon 260ci / Ford Motor Company (USA) / Darel Dieringer (USA)
#903 Ford Falcon 260ci / Ford Motor Company (USA) / Peter Revson (USA)
#904 Ford Falcon 221ci / Ford Motor Company (GBR) / Roy Pierpoint (GBR)
GT 3.0
GT 2.0
#58 MG B Rally / British Motor Corporation (GBR) / John Young (GBR)
#122 Volvo PV 544 Rally Sport / Volvo AB (SWE) / Tom Trana (SWE)
#154 Volvo PV 544 Rally Sport / Volvo AB (SWE) / Gunnar Andersson (SWE)
GT 1.6
#16 Lotus Elite Super 105 / Team Lotus Engineering (GBR) / David Piper (GBR)
#77 Alfa Romeo Giulia TI / Alfa Corse (ITA) / Pedro Bello (MEX)
#69 Lotus Elite Super 95 / Chester Automotive Racing (GBR) / Chris Kerrison (GBR)
#13 Porsche 356B 1600 GS Carrera GT / Glöckler Racing (FRG) / Paul-Ernst Strähle (FRG)
GT 1.0
#74 Mini Cooper / Liefeld and Associates (GBR) / Marshall Liefeld (GBR)
#9 Fiat Abarth 850 TC SS / Abarth Corse SpA (ITA) / Oddone Sigala (ITA)
#961 Saab 60 / Saab AB (SWE) / Per Olsen (NOR)
#962 Saab 60 / Saab AB (SWE) / Björn Larsen (SWE)
Entry list for the Course Sprint RACB de Spa-Francorchamps
GT +3.0
#5 Aston Martin DB4 GT / David Brown Racing Department (GBR) / Peter Harper (GBR)
#7 Aston Martin DB4 GT / David Brown Racing Department (GBR) / John Campbell-Jones (GBR)
#78 Shelby Cobra 260ci / All American Eagles (USA) / Jim Wester (USA)
GT 3.0
#2 Mercedes-Benz 300 SLS / Gilberte Thirion (BEL) / Gilberte Thirion (BEL)
GT 2.0
#230 Citroën DS 19 / André Pilette / André Pilette (BEL)
#969 Saab 96 Monster / Saab AB (SWE) / Erik Carlsson (SWE)
GT 1.6
#77 Alfa Romeo Giulia Sprint / Alfa Corse (ITA) / Pedro Bello (MEX)
#60 Porsche 356B 1600 GS Carrera GT / Auto Ruf (FRG) / Alois Ruf Sr. (FRG)
GT 1.0
Entry list for the ASK Roskilde Ring Sprintløbet
GT +3.0
GT 3.0
GT 2.0
#31 Porsche 356B 2000 GS Carrera 2 / Porsche System Engineering (FRG) / Jochen Neerpasch (FRG)
#580 MG B Rally / British Motor Corporation (GBR) / Henry Nurmester (GBR)
GT 1.6
#52 VW Karmann Ghia Super 90 / Volkswagenwerk AG (FRG) / TBA (TBA)
#11 Porsche 356B 1600 GS Carrera GT / Ecurie Maarsbergen (NED) / Gerhard Mitter (FRG)
#46 Sunbeam Alpine Series II racing / Sunbeam Talbot (GBR) / Ralph Bowyer (USA)
#144 Sunbeam Alpine Series II racing / Sunbeam Talbot (GBR) / Piero Scotti (ITA)
#12 Porsche 356B 1600 GS Carrera GT / Ecurie Maarsbergen (NED) / Henk van Zalinge (NED)
GT 1.0
Entry list for the AvD Nürburgring Sprintrennen
GT +3.0
GT 3.0
#716 Mercedes-Benz 300 SE / Heinrich von Schweinichen (FRG) / Heinrich von Schweinichen (FRG)
#28 Ferrari 250 GTO / Scuderia Ferrari SpA SEFAC (ITA) / Jo Siffert (SUI)
GT 2.0
GT 1.6
GT 1.0
#50 Alpine A110 1000 75 Berlinette / Equipe Pavellion (FRA) / Claude Savoye (FRA)
#51 Alpine A110 1000 75 Berlinette / Equipe Pavellion (FRA) / Jean Guichet (FRA)
Entry list for the CASC Mosport Park Sprint Race
GT +3.0
#515 Maserati 3500 GTi Corse / Scuderia Filipinetti (ITA) / Piero Frescobaldi (ITA)
#902 Ford Falcon 260ci / Ford Motor Company (USA) / Roy Pierpoint (GBR)
#904 Ford Falcon 221ci / Ford Motor Company (GBR) / Darel Dieringer (USA)
GT 3.0
GT 2.0
GT 1.6
GT 1.0
Entry list for the SCCA Daytona Sprint Race
GT +3.0
GT 3.0
GT 2.0
GT 1.6
#46 Sunbeam Alpine Series II racing / Sunbeam Talbot (GBR) / Giorgio Becucci (ITA)
GT 1.0
#113 Alpine A110 1000 75 Berlinette / Société Automobiles Alpine (FRA) / André Simon (FRA)
Entry list for the AMA Carrera Sprint de Ciudad de México
GT +3.0
#900 Ford Falcon Holman & Moody Challenger 3 / Ford Motor Company (USA) / Marvin Panch (USA)
#901 Ford Falcon Holman & Moody Challenger 3 / Ford Motor Company (USA) / Jocko Maggiacomo (USA)
#902 Ford Falcon Holman & Moody Challenger 1 / Ford Motor Company (USA) / Roy Pierpoint (GBR)
#903 Ford Falcon Holman & Moody Challenger 1 / Ford Motor Company (USA) / Peter Revson (USA)
#904 Ford Falcon 260ci / Ford Motor Company (GBR) / Darel Dieringer (USA)
GT 3.0
#800 Mercedes-Benz 300 SLS / Autosport Mannschaft Gelsenkirchen / Jackie Stewart (GBR)
#801 Mercedes-Benz 300 SLS / Autosport Mannschaft Gelsenkirchen / Mauro Bianchi (BEL)
#802 Mercedes-Benz 300 SLS / Autosport Mannschaft Gelsenkirchen / Ricardo Rodríguez (MEX)
#700 Mercedes-Benz 300 SLS / Team Cunningham / Pedro Rodríguez (MEX)
GT 2.0
GT 1.6
GT 1.0
#110 Alpine A110 1000 75 Berlinette / Société Automobiles Alpine (FRA) / José Rosinski (FRA)
Entry list for the ACA Carrera Sprint de Buenos Aires
GT +3.0
#515 Maserati 3500 GTi Corse / Scuderia Filipinetti (ITA) / Dante Emiliozzi (ARG)
GT 3.0
#802 Mercedes-Benz 300 SLS / Autosport Mannschaft Gelsenkirchen / Juan Manuel Fangio (ARG)
#65 Ferrari 250 GT California Spyder / Equipo Castelldefels / Juan Manuel Bordeu (ARG)
GT 2.0
GT 1.6
GT 1.0
#113 Alpine A110 1000 75 Berlinette / André Simon (FRA)
Injured drivers by date of next availability:
Angelina Sokoloff: 3rd January 1963
Jackie Stewart: 12th February 1963
Syd van der Vyver: 15th February 1963
Hachiman Setou: 27th February 1963
Chris Lawrence: 4th May 1963
Fritz Hahnl, Jr. : 17th May 1963
Juan Manuel Fangio: permanently retired
Paul Russo: permanently injured
Entry process
Car limitations
Drivers
Liveries
Points system
Calendar
GT +3.0
GT 3.0
GT 2.0
GT 1.0
GT +3.0
GT 3.0
GT 2.0
GT 1.0
GT +3.0
GT 3.0
GT 2.0
GT 1.0
GT +3.0
GT 3.0
GT 2.0
GT 1.6
GT 1.0
GT +3.0
GT 3.0
GT 2.0
GT 1.6
GT 1.0
GT +3.0
GT 3.0
GT 2.0
GT 1.6
GT 1.0
GT +3.0
GT 3.0
GT 2.0
GT 1.6
GT 1.0
GT +3.0
GT 3.0
GT 2.0
GT 1.6
GT 1.0
GT +3.0
GT 3.0
GT 2.0
GT 1.6
GT 1.0
GT +3.0
GT 3.0
GT 2.0
GT 1.6
GT 1.0
GT +3.0
GT 3.0
GT 2.0
GT 1.6
GT 1.0
GT +3.0
GT 3.0
GT 2.0
GT 1.6
GT 1.0
